Short_Shot
- Jul 13, 2021
- 1,823
Oh and if you're in an industrial or otherwise commercial situation the above disposal is not acceptable however and you're subject to various regulations on the matter.
This is primarily to prevent large scale abuse.
(I'm the containment/spill guy at work)
At home dumping sulfuric acid down the drain is only a risk if it's concentrated enough to damage your sink or pipes or if you're dumb enough to splash it on yourself. Not only is it not regulated but as stated previously there are sulfuric acid products designed to be dumped down the drain.
Just be sure you safely dilute it rather heavily before pouring it by adding the acid to the water rather than the other way around.
