Hi,
I have a 11.5kW grid-tied solar system using a SMA Sunny Boy 6.0 and 3.8 US-41 inverter both with the secure power supply (SPS).
I have started looking into adding Lithium Iron Phosphate batteries to the system as both a backup power during outages and to be used at night or other times the panels are not receiving solar energy to help reduce the power bill.
I'm looking into building my own system as the cost to purchase and have battery systems installed is quite high. (As one example the company who installed the solar say they can install a 10kW Sonnen Core to a 6 breaker critical load panel for $13k).
I've tried getting information about the SMA inverters, but as others have mentioned in other posts in this forum it is quite difficult. When I spoke to SMA tech support they couldn't even answer my question about what battery voltage the inverters can accept. They passed me off to someone else but they are just trying to get me to buy the SMA storage inverter and ABU in addition to the battery without answering my questions. The system looks like it has some great features but definitely not cheap for the entire setup.
I was finally able to get some information from another local solar installer about the SMA inverter. It accepts 48V but in order to connect batteries to it I would need to get a conversion kit for $500 which is not a big deal. However, according to him if a battery system is connected directly to this inverter it has no way of monitoring the batteries and will not switch between the battery and grid automatically nor will it keep it charged appropriately.
So, with all that background information my question is, has anyone built their own battery system including the BPS, charge controller, and other electronics to monitor the power and then switch between solar, battery, grid safely?
What equipment do you recommend?
Do you have experience interfacing with the SMA sunny boy inverter?
I would appreciate any insight you have to get me going in the right direction as I have just started to dig into this and thankfully came across this forum.
Thanks
Thanks
