Thank you so much Hedges,
I change The Max AC Charge current to 20.100 AC I simulated a grid outage and seemed like it worked. I do log in to the system VIA the LAN and WLAN. and Yes it 32 mA is a ground-fault limit.
I did change this value back its original value which was 60A from 25A which i set, but neither should trigger the ground limiter. Isn't it?
