Hi guys, I see that copper connection bars at 4 meters are pretty cheap. I can get 4m at 30x10mm rated for 800 As for like 250$.
Is there any downside in making your own bus bars from a bar like that and even replacing some of the cabling to the inverter with them? Just cutting them with an angle grinder and using a Pilar drill machine. Are the ones you get designed to be battery busbar polished in anyway?
Another thing I was wondering about is, if connection is so important, why are straight holes made in busbars and not a threaded hole? At least with a little thicker busbar (especially if it’s 10mm) the difference in the connection area between a threaded bolt going through a slightly too big hole in the busbar vs a screwed into a threaded hole through the busbar wouldn’t be insignificant. Or what is your thought on that?
I am also having a bit of a hard time estimating the impact of increased resistance. Resistance is proportional to length, right. But a bigger busbar — decreases — resistance right? Saw on some YT how someone got a thicker busbar and said something like, “oh the bigger busbars will have more resistance but I think it’s irrelevant” (OGG). But the opposite is through right, a thicker busbar should reduce resistance unless I am misunderstanding something (perfectly possible)?
Lastly, copper should be fairly easy to weld with gas. A welded connection shouldn’t be any worse from a connectivity POV right? I am thinking of running a copper plate right to the inverter form the battery.
Lastly 2, I’ve also been wondering if it’s possible to paint the copper bar with some kind of rubber coating/dielectric coating to make it more secure. Do anyone of you guys have experience using coatings on busbars/copper bars?
