theoldwizard1
- Jul 17, 2020
- 77
I have a background in electrical engineering, but I have not done any is about 30 years. The EG8011 IC and associated EGS003 controller/driver board do all of the "heavy lifting". There are schematics that show how to implement and inverter (120V/240V 60 Hz or 220V-240V 50 Hz) with very few additional parts. The key id your choice of a "high frequency (technically, a high voltage input) design or a low frequency (low input voltage) design. Low frequency designs require require a large output transformer. The most efficient low (50 Hz or 60 Hz) transformers should use a toroidal transformer (more efficient than E-core) which requires winding on a silicon steel core. Equations for calculating the winding wire size and number of turns exist.
Where can you buy silicon steel in a long thin strip (about 50-100 mm wide) to wind into a toroid ?
