Do you or anyone else know what/how to expand the info. box. I have done it several times but evidently by accident and can not for the life of me duplicate it. Here is a snip it of it when it happened one time but as I said I can't deliberately make it happen. This was grabbed from a laptop I couldn't set the proper resolution so it's a bit cramped. I switched laptops and was able to get it to do it again once...Hi please see my batteries results when they were depleted
I rather suspect that it is not meant to do that. Although I too have seen it.Do you or anyone else know what/how to expand the info. box. I have done it several times but evidently by accident and can not for the life of me duplicate it. Here is a snip it of it when it happened one time but as I said I can't deliberately make it happen. This was grabbed from a laptop I couldn't set the proper resolution so it's a bit cramped. I switched laptops and was able to get it to do it again once...
Hi, somewhere in Pytes manual I've read that the software is designed for screen resolution 1920x1080, I have tried couple of laptops until I get the right screen output, and still sometimes I get messed up views when switching between tabsDo you or anyone else know what/how to expand the info. box. I have done it several times but evidently by accident and can not for the life of me duplicate it. Here is a snip it of it when it happened one time but as I said I can't deliberately make it happen. This was grabbed from a laptop I couldn't set the proper resolution so it's a bit cramped. I switched laptops and was able to get it to do it again once...
Device address : 1
Manufacturer : PYTES
Device name : E-BOX-48100R-C
Board version : SQBMSV15
Main Soft version : SPBMS16SRP2205V1.5.18.C16
Iterate version : SPBMS16SRP2205V1.5.18.C16.T3
Soft version : V1.5
Boot version : V1.14
Comm version : V2.0
Release Date : 23-12-07
Barcode : ##############removed#################
Board ID : ##############removed#################
Board SRAM Size : 96KB
Board FLASH Size : 512KB
Specification : 51.2V/100AH
Cell Number : 16
Max Dischg Curr : -102000mA
Max Charge Curr : 102000mA
Console Port rate : 115200
