DouglasPaul
Will using a grid plug in charger while it is hooked up to the battery damage it?
The only catch is that the amount of Charging Amps cannot exceed the Max amount that the battery pack(s) can take.
A-Typically, a BMS will cutoff charge above a set amperage or voltage. BMS' vary and we have seen some "non-smart" BMS allow far too much with bad results. Even some smart-bms' come programmed with lousy settings but anyone with sense fixes those settings. With LFP the general average is that cells can discharge at 1C and take charge at 0.5C. For example a 100AH Battery can output 100A for 1 Hour but only take 50A for 2 hours to charge. This of course assumes these are 100AH cells rated as such.Wouldn't the batteries' BMSs determine how much current they pull?
Thanks, I thought that was the case but figured I would ask rather than just plugging it in. Appreciate the info.
I don't think this is accurate. It may reduce the total lifecycle count from some theoretical ideal, but if you aren't giving it too much voltage I don't see how it would bloat and ventWhat exactly would happen if a cell rated for 0.5C charging took 1C or more charge ? Heat up, Bloat & Vent itself ! How fast it would take ? not too long.
