When I gaze at your handwriting and locate marks scribed onto the wood, my blood pressure drops and my OCD all but vanishes.
You should see my sketch book and sheet cut plans. I hate waste. A wrong cut…. well I don’t want to talk about itWhen I gaze at your handwriting and locate marks scribed onto the wood, my blood pressure drops and my OCD all but vanishes.
Keep believing it, there also is fairy dust and magic wands that can be used.
No, I did not see that comment on the video. Thanks for pointing that out as it brings up the manufacturer's expected life cycle of the cell. It clearly indicates my current batch of uncompressed Eve304ah cells should last the next ~20years. Surely, by then, something much improved than the current best will be common place, and an environmentally friendly way to dispose of the old cells implemented.Keep believing it, there also is fairy dust and magic wands that can be used.
If he was serious about actual testing, it would have 2 sets of cells, one in compression and one set loose. Both in parallel and both at the same date/ batch of manufacture plus also entered into service at the same date. Then capacity test at one year intervals.
You must have missed this comment to this video:
@upnorthandpersonal
2 years ago
Instead of just randomly speculating, let's do some math. For one, the EVE datasheet states to expect a cycle life of >=2500 without fixture ('compression', yes, I know...) and >=3500 with. So we already increase our normal degradation by 28% by not having the cells in a fixture. Secondly, find some temperature discharge curves for LiFePO4 for example from Nordkyn et al. You should expect at least a drop of 2% at your current temperatures. Finally, a couple percent calendar aging. This also depends on temperature: the higher the temperature your batteries sit at, the faster the degradation - since you're in sunny hot Australia.... The literature has several models on this, but there are numerous variables I can't account for, but a couple percent is not out of the ordinary over the 4 year life since manufacturing. Based on all of this, 5%, or even 8%, doesn't sound bad at all. It would be good to do a capacity test again at 25C to at least remove that variable...
Exactly this.Hey, I remember writing that. And then I wrote a reply, and Youtube removed it...
Let me put it this way: I put my cells in a fixture. Whether or not it actually makes a difference I think only time will tell. That said, I'm now going into my 6th year with the first of my cells. They have been powering my house 24/7, winter and summer. I have no issues what so ever.
C'mon, when you're "low stress" you can do anything(within reason) and it'll be fine. The flaking and delamination I spoke of is a function of how quickly the growth happens(how quick you charge) and the temperature. Both things are affected by the current.I'm 18650 INR type chemistry rather than LifePo4 but I'm in year 7 and my opinion is growing that *low stress* (very low C, moderate DOD, moderate operating voltage ranges, moderate ambient temps, no physical issues) is a huge factor that's not well quantified in many of these speculations.
From my perspective, there were many 'what ifs' around 18650 4.2v chemistry when I started but they just haven't materialized for me. I'm over 2,000 cycles with 44% of my powerwall with no sign of degradation. The off-grid solar powerwall operates at <0.06C, 37% DOD within 3.5-4.0v range, 55F to 75F ambient - all low stress.
This makes me sympathetic to @timselectric posts - e.g. moderate compression won't hurt and can offer physical stability for practical reasons but perhaps moderate operations / less worry is worth considering for fixed, low stress solar operations.
At this rate it will take me another 14 years to reach 6,000 cycles at which point I'll probably be working on my DIY home fusion reactor![]()
Do you have the data sheet that shows how much a LiFePo4 cell expands/contracts with soc? Was it something like 1.3mm?One big thing for me is stress on cell terminals. Without compression, you can end up with cells slightly bloated like Andy had in the video shown in post #53.
My battery bank in my house has been in place for over 18 months, I don't have those issues shown in the video. I do have to wonder how many fires have been started by expanding cells in uncompressed fixtures. Probably more than many realize.
They don't tell us. L It may very well be pressure dependant, but I doubt as much as 1.3mm would happen even with no pressure at all. (all my testing is done with a compression fixture).Do you have the data sheet that shows how much a LiFePo4 cell expands/contracts with soc? Was it something like 1.3mm?
It is useful to think about two kinds of swelling. One (the one we're talking about here) is just the fact lithium takes more space when it goes into graphite (and lifepo to lesser extent). This kind of swelling, that happens during normal charging is perfectly fine and unavoidable. But it is not by a lot.They don't tell us because swelling is bad. They tell us how to prevent swelling by constraining the cells in a fixture.
Lucky you, being able to source CCA cellulose material. We just have the orange variety around here. Better than no pressure treatment, but definitely not as good.I found the pressure treated cells have a remarkably stable SOC and shelf life
Other cells I've slightly compressed in the typical plate and threaded rod approach
