shavermcspud
- Mar 12, 2020
- 577
What alarms?No luck, 2 Alarms today. Same as befor
I just left the settings as standard, did you change anything?
What are you trying to achieve as your end pack voltage?Its the alarm coda described above. "Over voltage battery hardware". Means somthing like the BMS has detected an overvoltage and has shut down charging.
Try using 3.45V as 100%. That way your BMS will not shut off, and your cells will last longer.I left them all standard. I'd like 100% charged so allow the BMS to prevent further charging by setting 0 charge current through the canbus. But for some reason the inverter seems to charge when the bms says not!
Hello. Would you be so kind as to explain what parameters must be set, both in the inverter and in the SEPLOS, so that it does not give errors using the "AoBo-Sofar" configuration? Thank you very much
There isnt a great deal to "set" change the inverter battery type to AoBo and set the BMS to sofar can communication, restart both units and that's it.
Could you give the values you set for the voltages or screenshot of your setting pleaseUpdate on this - I am on the AoBo setting and have set voltages in this to sensible values. No alarms and the battery charges to 100%! Success thanks to all!
There are basically no settings for the aobo battery. Just select it and off you go. These are the control parameters i have used though.
I have the 200amp BMS and my RHI is 6kW so max 100amp, mine always tops out at 61amps max, even though settings dictate otherwise.It does its rated 100amp in either direction? Why, are you not getting that?
