The DC might catch fire. AC switches first, then DC. A good idea might be a 3m cord tied to the positive DC with the label "in case of emergency, stand back and pull cord" lol. Might sound very silly but I'd rather have that than just be looking at an arc fire I can't stop.In an emergency I'm flipping off everything, load or not. It should work at least once, right?
I'm required to have at least one on my truck.I'm curious does anybody keep a electrical fire extinguisher (powder?)?
It's not a confusing subject, the IMO was designed specifically to switch DC current under load.Thanks for the great explanation..wish I had known this earlier… when buying my IMO device last year I couldn’t get a solid explaination on that from anyone…when I asked no one knew any real facts.
when reading the sales info the “Disconnect Switch ” version was rated at a high number of full load disconnects ( 1000 +/- or something .??? ) discussed the speed of the disconnect and the distance of the contacts when open.…the isolater didn’t seem to state those same facts , but we’re very simalar on other stuff…confusing..!
I chose the SWITCH…..with about a 33% amperage safety margin for headroom, relative to my array max power..
I have switched it off and on a lot this year under load…..So far, No Problems …
It is a confusing topic ..
J.
saving money can be a great thing on somthings , sometimes …BUT the real deal IMO switch is only about 100 bucks… why would anyone be trying to save money on somthing so important and is already cheap…An IMO is rated for switching under load, let's clear up any misconceptions or confusion some might have about the IMO. If you don't believe it, then contact the fella in this video and maybe he will clear that up for you.
As for the original video I linked and the following video in the next post, it mentions that if an inverter or isolator has RSD, then the addition of another isolator is redundant and not needed. If you have a string of panels like most of us do on a ground mount without any method of shutdown, then yes, you will need to add an isolation device for disconnect. I think some of the manufacturers of micro inverters and isolators are pushing for this to be in the code to increase the sale of their devices.
If you have rooftop solar, you are required to have isolation to meet the disconnect requirements for fire fighter safety at the module level. Ground mounts do not have to meet this requirement. Preferred method to keep costs down is still ground mount, for me it is not a hard decision to make. Those with limited real estate most likely will have to use roof mount and meet those requirements.
In AU, the requirements are different, this post here shows what they have been doing in the photo. https://diysolarforum.com/threads/solar-economy-is-it-healthy.72148/post-959326 In the following post, it was stated that Finland had changed the requirements for rooftop isolators.
This post relates the majority of fires on rooftop PV was caused by isolators. https://diysolarforum.com/threads/solar-economy-is-it-healthy.72148/post-959636
From what I have seen thus far, it appears the manufacturers of RSD devices are pushing for rules to use their devices, even if those devices cause the majority of fires. As for fires related to devices that copy the IMO, I would say those devices were not made to the standard the IMO meets. These are the import copies most people purchase to save a buck.
Yes it was confusing before I learned the facts… I had never even heard of this device ….there’s a lot of copies of things out there.. the copy people are counting on the fact that most don’t do their due diligence and research the topic and gear…after talking to the manufacturer specifically about breaking the circuit under load it I made my decision and have been pleased thus far… I have never bought and will never buy a Chinese cheap copy of anything.It's not a confusing subject, the IMO was designed specifically to switch DC current under load.
I had linked the video presentation in other threads, it clearly stated the IMO is switch rated. As for import copies, well, you are on your own.
RTFM ?It always boils down to,
Make sure that what you are using is rated to do what you are using it for.
I couldn't remember what that was.RTFM ?
The fire was not a huge thing, eventually would/could have doused with some flour or soda
The IMO was designed specifically for this purpose. Use it. Don't buy import copies.So what is the collective verdict on this type at the array's and/or at the head end, just before the inverters?
IMO DC Disconnect Rooftop Isolator Switch
IEC 60364-7-712, dc disconnect, imo, ul listed, DC AC, DC DISCsignaturesolar.com
You can use your own enclosure. What you keep seeing for sale/shown is the "enclosed SI" series. You can get panel mount version.These IMO isolators look nice. I wish they offered steel enclosure option instead of plastic.
Someone may have mentioned this but cover a few with a blanket, this will drop power down.Mine is built into the inverter (Solis)... But if you don't have an isolator, how do you isolate panels if you need to work on them?.. you're not supposed to disconnect MC4's when there's a current running through them.
