Yes but the battery is 68kWh, where are you going to get the power from? You likely need to use the j1772 power adapter and somehow trick the system to allow charging while driving if that's your thought.
Could either plug an adapter into the charge port or modify the port so there's a 2nd input.
1000w of solar on the roof will only make like 3kwh a day and you'd likely need to convert DC to AC then the van will bring back to DC. So it'll take a month to charge
