Traviss224
- Jun 25, 2022
- 322
This is the humor section.I noticed Tim laughing at this post
Missed That !This is the humor section.
It definitely is.It may not be the humor section.
Capacitive coupling of AC from the inverter. And it hurts. Not humor.How does the frame have any power on it?
It definitely hurts.Capacitive coupling of AC from the inverter. And it hurts. Not humor.
All metal surfaces you can touch should be "grounded", meaning that there is an Equipment Grounding Conductor (EGC) from the main panel, to every metal device, including the inverter case (there should be a grounding screw), and the PV panel frames and mounting.So we are earth grounding solar panels that has no power going to them but were not earth grounding your inverter inside the house???? Im not trying to be humorous with this. I'm being serious. I'm fairly new.
