Hi, yes, I have this inverter, the PGH1. Its a decent 'smart' inverter. When its on Eco mode, its consumes less than 4 watts, but i get a lot of faults with Eco mode, when I plug stuff in while in Eco mode. It should turn on when it detects a 50 W or more load, but it just seems to fault for me. It works perfectly when in Normal mode. I'm currently talking to tech support about the Eco mode issue.
I'll have to do more troubleshooting myself, as my loads are connected to the inverter by a power bar that has surge protection with an on/off switch. Not sure if this could be causing the eco faults, but, how else do you use a inverter if not with a surge protected power bar?
