jtown
UPDATE: I had another issue in my system that has now been resolved and have narrowed down my issues with the Inverter-Charger.
I recently installed my 3000W Renogy Pure Sine Wave Inverter-Charger.
When I am not connected to shore power and the inverter-charger is not using the bypass function, I get the following readings from the output (photos #1-3):
- hot-neutral: 120V
- hot-ground: ~25V
- ground-neutral: ~25V
However, as soon as I am connected to shore power and the inverter-charger is using the bypass function to go directly to my AC loads without charging my batteries, then the output of my inverter-charger works great. I get the following readings (photos #4-6):
- hot-neutral: 120V
- hot-ground: 120V
- ground-neutral: 0V
It doesn't seem to matter if I turn the inverter-charger off/on or the whole system off/on. I get the same readings when the bypass function is being use and when it's not as described above.
Any help greatly appreciated.
- hot-neutral: 120V
- hot-ground: ~25V
- hot-neutral: 120V
- hot-ground: 120V
