I have a list of things that people new to DIY solar should do.
1) DO NOT BUY ANYTHING YET!
2) Get a good intro book - Solar for Dummies is one. A book on basic electrical theory would also be good.
3) Find a friend who does this for a living, buy him dinner and pick his brain. Ideally a solar installer, but an electrician, electrical engineer or solar industry person are also good options.
4) DON'T BUY ANYTHING YET! I don't care if you see a great deal; it's probably not, and even if it is, you will probably find it incompatible with what you are doing.
5) Once you have the background, go on to a forum like this one and ask general questions. Read the FAQ. You'll learn a lot.
6) If you still really, really want to buy something, you can buy a 12V panel, 12V MPPT charge controller, 12V battery and 12V inverter. Make them small and cheap because you'll probably damage them. Also get a good meter with DC inductive sensor. Build it and put some simple loads on it. Again you'll learn a lot.
7) Start planning your system. Calculate your loads. Buy a Kill-a-Watt or similar plug in meter to get accurate energy requirements for air conditioners, refrigerators etc. Come up with total solar watts, total storage kilowatt-hours, peak output power and average output energy.
8) Publish your ideas on a forum like this one and get feedback.
9) Anything you get off the web - check it against a real person before you rely on that advice.
After all that, if you still want to proceed, THEN start buying stuff.
