Travel Ken
From one of Will’s YouTube videos from three years ago I noticed an interesting, possibly more powerful way to automobile charge an EcoFlow power station.
I recently bought an EcoFlow Delta Max 2000, that I plan to use in my travel trailer. I want to recharge this unit via a alternate DC input from my high capacity truck alternator, but the Ecoflow OEM supplied automobile charger, will only produce a dismal 96 watts (12vdc@8 amps). I’m wanting to increase that charging rate. In the aforementioned video I see an adjustable bench top power supply used to mimic a higher DC voltage solar input. In this video he set this bench top adjustable power supply to 30 volts @ 5 amps and achieved 136 watts of charging. Note: this EcoFlow unit only has a single DC charging input, (XT60) used for either “automobile” charge or “solar” charge. The user manual for my EcoFlow states “Solar Charger—— 11-100V 10A, 800W max”. Question, could one recommend using an external fixed, 12vdc to 48vdc, 10 amp step up converter to achieve my desired higher charging rate (480 watts)? If so, what step up converter would be recommended?
Video referenced:
“Ecoflow Delta Review: Pros and Cons/ Capacity Test/ Technical Discussion and More”
Video referenced:
