I am building a skoolie and plan to use my EcoFlow Delta Pro to power essential electronics. I originally wired the low voltage side to use an AGM house battery with a chassis ground.
I would like to substitute the EcoFlow for the AGM since the loads are less than 20amps. Can I connect the negative receptacle on the 12v Anderson output to the chassis ground without damaging the unit?
Thanks in advance.
Thanks in advance.
