I have 3 separate systems here off grid. I have a situation where I am setting up a solar only system near our cabin and want to run supplemental power in winter (when we only have rain...) to charge this system from a hydro based system about 800' away. I have a 10AWG UF wire run from the hydro system to the new solar only system. Looking for ideas to run maybe 1000-2000 watts (or more?) over that cable to the new system as efficiently as possible.
I am planning the new solar based system to be 48V nominal
My original idea was to run 120V ac from the remote inverter to a 48V battery charger on the new system. Having trouble finding an efficient 48V charger.
Next idea was to find a 56V AC to DC power supply and run the DC output to a cheap MPPT charge controller, but again, the power supplies seem to all be clustered around max 85% efficiency, added to the MPPT losses and wire losses and well, that leaves a lot to be desired...
Got to be a better way to do this.
Need some other ideas from you folks who are smarter than me.
At 800ft the southwire voltage drop calculator says thats a 20.99% voltage drop using 10 guage wire. A couple thoughts come to mind.
Power companies run like 14,000 volts to tranformers and then from the transformer you will get 600v to houses for only a short distance away.
They use aluminum in the air for cooling and costs. Run your lines in the air with ceramic isolators on the poles.
I think I remember at 900ft 120v drops to like 110v using 2guage wire. The cheapest wire you will find is mobile home connection wire. If I remember correctly its 2 guage and 4 strands. If you are just doing single phase connect two strands to have two pairs to get double the thickness... kind of. It was $500 at Lowes for $500 ft. For 4 conductors. Use thenlarge splices that bolt onto the wires and adhesive lined heat shrink and use 3m 5200 over that heat shrink. Don't forget dielectric gease inside also. You have to look for the lowest price and some Lowes were cheaper than others. Home depot was more expensive. Costs have gone up over the last year though.
Feed a few batteries at the hydro. Get a european 240v MPP inverter to run off a couple batteries. American 240v is not really 240v its just two legs of 120v split phase so get a European inverter. MPP has an alibaba page and you can buy directly from Taiwan like I did. Then you could use a smaller wire size and get a step down converter with a range of 240 volts down to 120v. You will get half the voltage drop at 10.5% for 240v.
Use a ram water pump to feed the water at 1:7 run to rise ratio to a tank/pond put the hydro at the pond next to your house, then use the water to feed your property or swimming pond/waterfall.
A ram pump with high starting pressure from a stream would do great at getting water up a hill. Start with 10 inch pipe in the stream and work down to a 1 inch ramp pump to get high psi. Maybe have a pond that fills all day and a waste gate that opens when you get home at night to create power and fill batteries when solar is not being produced. Even a solar pump could fill the pond all day. Have the pond drain to a second pond, that flow can also have a ram pump send water back up to the top pond and the over flow goes to the second pond.
FYI a washing machine on its' side has the longest lasting wet to dry seal you will find. Remove the washing machine motor and put your alternator on the shaft, remove the drum inside and put the water wheel on that side of the shaft. Now you have an alternator that wont get wet and corrode. There is a washing machine hydro guy on youtube.
