EG4TechSolutionsTeam
Online Support for EG4 Electronics
did you figure this issue out? was it just an update after all? im having the same alarm codes. the one im working on is completely off grid with no generator.
I would make sure the Grid Loss Warning Clear is enabled or if this is on an older firmware, it would be called Run Without Grid. Also, if this was connected to the monitoring system, you could DM me the serial number for the inverter and I can take a look.
