I'm really liking what I see with the EG4 18KPV but I have a few questions. I'm in the middle of an energy audit now and I have a baseline of around 900-1000w of continuous usage before items like HVAC and other appliances factor in. I'm using about 30-40 Kw a day. This will probably go up for summer and winter, but I'm not sure by how much because I'm getting a geothermal heat pump installed.
I tried to push my usage as high as I could today by running the old air conditioner, the oven, a toaster oven, microwave, tea kettle, everything I could find and I got right up to 13Kw. The max output for the EG4 18KPV is 13.5Kw.
- What happens if I have an 18KPV and I push it to 14 Kw for half an hour? Do circuit breakers trip?
- I will not be pushing to the grid. What happens when production is more than consumption?
- Are there any BMSs that the unit can communicate with or do you have to set it to lead battery when you have a DIY battery bank?
- Can I programmatically set the unit to charge the batteries from the grid? The scenario is using Home Assistant, seeing that the next day is cloudy and charging overnight in anticipation of a low production day.
