Systems Planet
- Jun 25, 2020
- 36
My EG4 is producing power!
I'm running in an off-grid mode with four 345 watt panels.
What I experienced:
- no battery rack
Still waiting. Signature Solar quoted 6 weeks delay.
The cables from the inverter are too large to attach directly to the batteries.
You'll need to wait for the rack or your can rig something up like I did.
I found a longer 1/4 28 bolt that would accommodate the enormous connector.
- battery cables have the wrong ends
I had to mangle the end with a sledge hammer so it would fit into the inverter.
- the dongle wouldn't let me upload firmware.
Fortunately it did let me set my wifi password.
Leila at Signature Solar pushed the latest firmware.
30 minute hold time.
60 minutes of phone support.
Mostly waiting for firmware to load.
- caps don't fit over the holes on the bottom of the unit
Be ready to grind down the tabs left by the cutout slugs with a file.
- no diagram of how to connect the communication hub
I attached a photo
My panels:
EPS 18kpv + Lifepower4 bundle:
signaturesolar.com
Bottom Line
I am a T4 complete paraplegic and stroke survivor
(that means I only have my arms and half a brain).
I was able to build a solar panel mount from wood,
mount the panels (with a little help),
unbox the inverter and mount on the wall,
get everything configured and running with little support.
If I can do it, you can do it!
Up next:
What I experienced:
- no battery rack
I attached a photo
My panels:
Mission Solar MSE345SX5T 345Watt 60 Cells BoB Monocrystalline 40mm Black Frame Solar Panel
Shop Mission Solar MSE345SX5T 345Watt 60 Cells BoB Monocrystalline 40mm Black Frame Solar Panel online or call us, Solarflexion, at 800-942-2424 for your solar needs.
www.solarflexion.com
EG4 18KPV Hybrid Inverter System Bundle - 30.72kWH EG4 Lithium Powerwall [BNDL-E0005]
EG4 Hybrid Inverter System with 30.72kWh Lithium Powerwall Bundle: Powerful off-grid solution for sustainable energy independence.
Bottom Line
Up next:
