I currently have my EG4 18kPV setup as charge controller only. Two interesting things I've come across that I haven't seen mentioned yet.
- If you turn off all AC output the idle load drops to 16W-20W.
- If you limit the PV output to 100A the fans were not on. As soon as I raised that to 200A (and I had enough PV power that it was being limited) the fans kicked on and it was much louder then I was expecting. It appears to run the fans at full speed. Ambient temp it is in is probably around 50F.
