JBoffgrid2022
- Oct 28, 2022
- 153
Hello All,
Here is my setup:
EG4 6kW Off-Grid Split Phase Inverter (1)
EG4 LifePower4 Lithium Battery | 48V 100AH (4)
EG4 Enclosed Battery Rack (1)
SunPower 450W Mono Solar Panel (Silver) A-Series Solar Panel (16) 2S8P
Looking for some guidance on setting #17 "Battery Wakeup". My setup is located in an off grid camp that has no back up power ability at the moment. Up until four days ago, I had great communication and read outs from the inverter via mobil wifi which was powered by the inverter/camp. The battery bank depleted unfortunately beyond the 20% cutoff mark and has shut down. I lost all communication with the inverter since that happened. I was really hoping after a day or two of good sun, the inverter would wake back up and supply power once again to the camp/wifi.
1. Does anyone know what the inverter is programmed to do in this situation? Does it have the ability to wake up from PV input, or does it need to charge the battery bank up to a specified SOC before turning back on?
2. If the inverter doesn't have any ability to wake back up, do you have any suggestions on how I could achieve this?
Thank you!!
Here is my setup:
Thank you!!
