Technine
I realize this thread is a little old but I just created an account to add my experience with getting my JK inverter BMS to communicate with my 6000XP.
This forum has been super helpful in figuring out my first battery build so I figured it was worth helping out for once!
The JK Inverter BMS manual has the CAN and RS485 ports mislabeled. I set the BMS CAN setting to Pylontech and set the 6000XP in li-ion mode with pylontech “2” as the make/model then plugged into the 2nd port to the right of the brown “relay connector” on the BMS communications board.
After figuring out they mislabeled the ports everything synced right up. I can now see the SOC in the eg4 dashboard and on the screen of the inverter. It currently shows 0AH for capacity though so I still have some more testing to do to see if I can get that part working.
