This past weekend I was out to dinner with the wife but happened to be monitoring SA and noticed that it was late in the day, sun was down and the batteries were just over 50%. Right now the output from the inverters is only powering a LED light and the heat pump in my shop, so a 1Kw load max when it's really trying to push the heat.
I know that 50% was not enough to run the heat pump thru the night, so I switched to the Solar Assistant Power tab and told it to override the source priority to SUB for 12 hours.
As soon as I did this, SA became unresponsive and said to connect to bluetooth.
We made it home about 90 minutes later and I found that my 2P1 inverter was flashing fault code F06. Per the manual this meant "Output voltage is too high". SA died because it was connected to the 2P1 inverter AC output via a USB dongle. My buck converter isnt connected just yet...
I'm trying to understand why this would have triggered. At the time I made the change there was 0v input from PV, I was running the heat pump off battery and the load reported in SA before I made the switch was just over 330w.
I had to power cycle the system to get it to resume working, so now I'm a bit hesitant to change between SBU and SUB for fear of the same thing happening. I am also about to start swinging circuits in the house over to the dedicated load panel but would like to figure this out before I wind up taking down power to key circuits (fridges, freezers etc).
I am 1 rev behind on firmwares.
Has anyone else seen this behavior?
