I currently have 4 EG4 Lifepower batteries. Solar assistant states the batteries showing differences in SOC but the voltages are similar. The main issue is battery 1. Any ideas on how to resolve this?
That battery never shows over 60% SOC. However, the battery voltage is usually similar to the other batteries. I am leaning towards faulty BMS reporting.
Of course not"Faulty" is misleading. If you never put air in a tire, and it loses pressure, do you say the tire is faulty... or do you attribute the pressure loss to improper maintenance? "Inaccurate" is totally acceptable, but all BMS have this limitation - including a Victron or other high end battery monitor that tracks SoC - if they don't sync regularly, they will not be accurate.
Did you try holding the absorption voltage for 4+ hours?
How do I do that? The 6500's don't have a setting for that. My offline charger is just a cheap one from Signature Solar.Did you try holding the absorption voltage for 4+ hours?
If a tire loses pressure, there is a leak. I am still going with faulty."Faulty" is misleading. If you never put air in a tire, and it loses pressure, do you say the tire is faulty... or do you attribute the pressure loss to improper maintenance? "Inaccurate" is totally acceptable, but all BMS have this limitation - including a Victron or other high end battery monitor that tracks SoC - if they don't sync regularly, they will not be accurate.
So, still leaks.....You know that air can diffuse out of a tire with no leak, right?
You've been given a path to pursue to fix your problem but you seem to just want to argue about semantics.Yes, I thought everyone understood that!
I was just replying to a douchbag response. A simple, "this is a suggested way to fix it" is better than a "don't you do maintenance you idiot"?You've been given a path to pursue to fix your problem but you seem to just want to argue about semantics.
SOC is a derived, calculated number. It is not a direct measurement. To reset the accuracy of this calculation, you need to fully charge your batteries. And hold that charge value for a period of time.
Instead of arguing about analogies, why don't you try and figure out how to accomplish this task.
Beside, I am in the process of selling all of my EG4 equipment. I am tired of the frustrations.
Not fragile at all . Just replying in kind.
Yes, I tried fully charging all batteries. The one never goes above 60% SOC. However all of the voltages are the same. So yes, the BMS is "inaccurate" aka "Faulty".
I just received two more Lifepower4's that I ordered before I decided to get rid of the EG4 stuff. So I am in the process of fully charging those and making certain that they all have the same firmware before selling them. I do not want to pass my problems to somebody else. I will be going the Sol-Ark route but have not decided on the batteries yet. So, looks like I will still be around.
So, you really don't see this as a childish response?I think the real issue is that you're frustrated, and you're prone to seeing negativity even when none exists. I'm assuming you're an adult, so you must have identified the fact that the world isn't simply black and white.
I only get frustrated when something does not work as intended.
When I designed LED controls years ago, I tested everything so the end user does not have to become an expert.
So yes, I get frustrated when a company does not test their products so they simply work.
