Try a road bike with 700c tires at 125psi, you have to top them off every time you ride. If I'm not mistaken the pressure loss is due to a combination of diffusion AND solubility of gas in the butyl rubber, in particular the CO2 fraction (assuming you are inflating with atmospheric air, or CO2 cartridges in which case your tires go flat faster).So, still leaks.....
OK, time for me to jump in.
I am having a similar issue and can follow advice/direction.
I have 4 x EG4-LL (v1) batteries. 3 bought at the same time, one a few month later. It is this later one that reports different state of charge than the others.
I have an MPP Solar LVX6048.
The EG4-LL (v1) manual states bulk/absorption 57.5v and float 56.5v. I have set the invert setting 17 & 18 respectively to these voltages.
Setting 21, stop charging or back to battery voltage per SA, has been set to 58v
The batteries go into standby mode before before reaching any of those numbers, even when setting the 1, output source priority is set to SUB to prevent switching from grid to battery output. No solar is being used. Batteries are charged via AC input on the inverter.
I have the batteries hooked up to solar assistant with this kludge from their website. Battery Comms are also connected.
I have tried the suggested fix in this thread previously without success. I may not have left things long enough however.
Would disconnecting all battery comms help? I will leave all batteries connected, and remove all comms. I can still view the total voltage of the 4 combined packs with the connected Victron Smart Shunt.
I think I will try anyway, but would still appreciate feedback.
Thanks.When Comms are enabled, absorption/float voltage settings are ignored. They are supplied by the batteries.
Thanks.
I've unplugged rs485 connections from batteries to SA, and unplugged all ethernet cables going from battery to battery.
I'll see where things stand tomorrow.
Batteries drained to 5% over night. Started charging 2ish pm today. Charging from AC input at 40a for the 4 connected battery packs. SA, when connected showed about 10a going into each battery pack.
Shunt currently shows SOC @ 45.7% at 53.4v
There is no pv hooked up so its already utility only, but I will take the advice and lower the voltage.Document the peak voltage.
IMHO, set to utility power only, absorption to 55.2 and float to 55.1V Those are lower voltages where cells should be able to get to near 100% charge, BUT there is reduce risk of sending one cell into over-voltage protection. HOLD them there for 24 hours to give time to balance. After that try to run to the prescribed charge voltage and see if you can get higher than the prior peak.
When was the last time that you reset the battery?Time to resurrect this thread. The BMS on the 3rd battery is faulty. Sent emails to SS but not response yet. It has only been one day on the latest round of emails. Here is 3 screenshots taken at different times. Note that battery 3 has not changed at all in each. So, it appears the BMS was faulty and became faultier since.
I will connect the BMS app this weekend. I restarted the battery a few times this last week.When was the last time that you reset the battery?
Connect the BMS Test app and share the data for each battery cell and any alarm conditionsfor that battery.
You have a connection problem with battery three. Parallel connected batteries should not show such a diverse voltage.Time to resurrect this thread. The BMS on the 3rd battery is faulty. Sent emails to SS but not response yet. It has only been one day on the latest round of emails. Here is 3 screenshots taken at different times. Note that battery 3 has not changed at all in each. So, it appears the BMS was faulty and became faultier since.
Looks fine, other than the SOC reading isn't accurate.
That wasn't the question. What voltage are you using is a charge voltage. Probably previously stated but I don't want to review all 50 posts.The batteries get charged to 100% daily.
Ok, Next time they hit 100% SOC...please post a screen shot of the cell data for all 6 batteries.The batteries get charged to 100% daily. This battery has no changes. It seemed like a connection issue but I checked that. It is in a Sig Solar battery rack.
Can you please tell me how you got these screen shots? I'm using windows 11 and this is the only program I've ever seen that doesn't support a screen shot by pressing the "Prt Scr" key. What is the trick?
Snipping Tool is built inCan you please tell me how you got these screen shots? I'm using windows 11 and this is the only program I've ever seen that doesn't support a screen shot by pressing the "Prt Scr" key. What is the trick?
