They absolutely can. This is even easier than running them in split phase. You just need paralleling cables that would be included with the pair.I know you can stack 2 of these to create a 13kW 240/120 split phase system. Do you know if they can be stacked to create a 120 volt 13kW system? Thanks!
We have a situation on the farm where we're considering 2 stand alone systems running up to 500' apart but on a common line to compensate for voltage drop.They absolutely can. This is even easier than running them in split phase. You just need paralleling cables that would be included with the pair.
Yes they will.@BenFromSignatureSolar, will the eg4-lifepower4-lithium-battery-48v-100ah plug and play with the EG4 6500ex-48 same as it does with the EG4-LL?
If we solved the communication issue what problems would you expect to experience? When you say fully independent systems do you mean panels, batteries and inverters? That's what we have in mind.Yes they will.
I would need some more information on that set up you're talking about. 500' could result in some issues. Namely that there would be no way to parallel the system at that distance. You would need 2 fully independent systems to make that work. I'm pretty sure that would go for any inverter.
Slaughter's is the joint my son in-law was bragging about yesterday when we were conspiring. What elevates Big Smith's early in the week?Yes, that is correct as far as the system goes. Good to hear that's what you are thinking.
If you come Wed-Fri there is a place called Slaughter's BBQ Oasis that is absolutely incredible!
If you are here earlier in the week I would suggest Big Smith's
You can't miss either way!
Oh it would be early...my chariot turns into a pumpkin at dark... and it's a 4-5 hour drive. What days is Slaughter's open?The fact that Slaughter's is closed! Big Smith's is always rock solid... but can't hang with Slaughter's. Come early because they sell out by noon most days!
