EG4_Jared
Online Support for EG4 Electronics
EG4LL-S batteries can be smoothly integrated with other EG4 48V models to enhance your energy storage capabilities. To guarantee seamless functionality, it's crucial to follow a few important steps.
MultiPack Firmware: Firstly, it's recommended to have the MultiPack firmware installed. This firmware enables compatibility between EG4 LL-S and different EG4 battery models, ensuring they work together.
Communication Cable Adjustment: Additionally, if you encounter issues with the LL-S initiating Rapid Shutdown (RSD) when the battery communication cable is installed and you do not currently have access to the MultiPack Firmware, there's a simple solution. By removing Pin 6 from the LL-S to Other model (such as Lifepower4/LL V1 or V2), you can prevent the LL-S from triggering RSD. Pins 3 & 6 serve as the RSD switch on the LL-S, and disconnecting Pin 6 resolves this issue.
![1717775287986.png 1717775287986.png](https://diysolarforum.com/data/attachments/220/220379-c16a7a1bc24d982abba3aff3579b9b6f.jpg)
