Hi Folks,
I've got an existing trolling motor with 3 group 31 AGM batteries wired in series to give me 36VDC to support a Minn Kota Ulterra. Its been working great, but the AGM batteries are starting to show some age. So I want to replace these with LiFePo4. But I'm trying to figure out my Battery Monitoring system out.
I have a Minn Kota MK345PCL charger which supports a Lithium charge profile. So I'm good there. I do NOT currently have the Shunt in place; but I want to buy that. Looking at the diagram I put together, you'll see the Victron SmartShunt I was looking at adding. I also was looking at the BattleBorn 100Ah batteries...because with the cylindrical cells, if there was a cell failure, I could continue to use but with the limited capacity till I get back home to replace it. Also, when camping, sometimes it gets below freezing in the Spring, so the low-temp charge disconnect is a plus. Finally, the build quality seems to very good; as I don't want to have a trip go short because of battery failure.
At any rate, the concern I have is with the shunt. I guess I can monitor the discharge rate with this configuration; but with 3 separate charge banks from the charger....the shunt will have no idea what charge is going into the battery.
For those of you that are using this kind of configuration, do you just reset discharge to 0 or set SOC to 100% and then just monitor the discharge?
Also, I want to disconnect everything from the batteries while charging so I don't have any parasitic discharge; I assume I can power the Smartshunt with the 36Vs on the switched side of my large 2 position switch (so its not powered when my 2 position switch is in the off position)? I'm not familiar with the Victron Shunts to know if you can configure them to auto-zero out everything on power-up?
Any better ideas or approaches with this setup that you suggest?
Thanks so much for any assistance or direction.
-J
-J
