OK... so I'm struggling with this. I have two Victron 24/3000/70-50 inverters. Trying to decide how to connect them (series or parallel). I have some 240V appliances I could power, but there are things I don't know. If for instance I have a 2,400 watt heating element (water heater), is that 2,400 watts per leg, or 1,200 watts per leg? So assuming I set them up in series (split phase), and I energize that heating element, would I still have 1,200 watts available from each inverter for 120V loads, or would it basically be maxed out and I couldn't run anything else while that load was energized? Please be gentle...
