JeepHammer
Solar Wizard
- Nov 15, 2019
- 1,149
Well maybe posts were edited, but I see no mention of any small van, an east coast winter, or any compelling evidence that Santa is a she (though I'm certainly not opposed to it, but I don't know how Mrs. Claus will feel)
Santa is a 'She', learning and building from scratch, and doing quite well!
Her plans are a 'Sprinter' type van converted to RV, and to travel to the north east soon as she's done.
She has cable, terminal ends, crimper, inverter, charge controller, breakers & fuse block, 2 BB batteries and PV panel set Will recommended for small RVs, and is using his plans.
She's working up cables, crimped, soldered, heat shrink, used the large/thick terminals, good cable, brass bolts, etc.
She has absorbed the Watts/Amps/Volts math, has sized her own cables for the inverter load correctly, and is now waiting on Amazon to stop canceling her orders so the panels get to her.
She has absorbed everything suggested on the different threads, asked relevant question about cleaning terminals, corrosion control, etc.
She's REALLY interested in doing things correctly, and scavenging every bit of information she can find,
And she's absorbing it.
Not only wants to know 'What', but 'Why'...
So... I'm trying to help where I can. Anyone that gets off their butt is just aces with me!
I'll help anyone that's willing to learn & work.
Now you are caught up!
I think the confusion was not knowing a 'Watt' is a measure of energy, electrical to heat is a 1:1 exchange,
Resistance heating is 100% efficient, 100 Watts of electricity converts into 100 Watts of heat.
Most times we talk about heat in BTUs, not Watts, and since she has grasped electrical Watts, it's clear to her now.
Watts to BTU, multiply by 3.12
100 Watts is 312 BTUs.
The heater unit is expensive, (knock-offs from China start at $100 on eBay/Amazon)
But consuming 1/4 gallon of fuel, 34 electric Watts per hour,
Makes 2,200 Heat Watts/6,864 BTUs an hour.
Batteries live MUCH longer at 34 Watts Load an hour!
2,200 heat Watt/Hr. would take 3 ea. $1,000 batteries so you didn't run them flat,
That's $3,000 for ONE HOUR (or just a little over) before you had to wait for them to recharge while freezing to death!
Gas heater, For $100-$1,200... 1/4 gallon of fuel, 34 Watts, 2,200 Watts of heat continuously as long as there is fuel in the tank.
For me, I might try a knock-off, If you got 1 winter out of it, it would be worth the $100-$200 price tag.
The Eberspacher unit runs about $1,200 before install!
You can get a home furnace for that! But the Eberspacher heater lives for YEARS in big trucks/RVs, so you kind of have to do the math and check the bank account...
