What I have read on forum 2p8s or 8s2p is that it is best to go with 8s2p with two Electrodacus SBMNS0. This way each cell is balanced individually.
Its not quite that simple, but that is definitely a valid and logical approach. Individual cell balancing and redundancy are two of the primary benefits of this approach (disadvantages include added cost and complexity). Particularly with the 280Ah grey market cells, which are large capacity and only loosely matched.
Dacian (Electrodacus -- the maker of the BMS you are considering) argues that the advantages of 'series first' are overstated, particularly considering that internally a prismatic cell is a bunch of lifepo4 cells in parallel, so the idea that you achieve 'true cell level monitoring/balancing' with non-paralleled packs of large capacity prismatics is an illusion. While I can't argue with his point, I think his argument carries more weight with higher quality matched cells, there are other reasons to consider series first if you are buying large capacity loosely matched grey market cells which may require much more balancing than matched cells would. This last point isn't a point in support of or opposed to series first, what it supports is the idea that with unmatched packs, keeping down the size of what your BMS sees as a 'cell' is more important, this can be accomplished through not paralleling cells, or using smaller cells. I'm not an expert on this and also not able to speak on Dacian's behalf, just sharing (hopefully accurately) what I recall reading elsewhere, mixed in with some of my own thoughts towards the end.
One other question that constantly confuses me and my apologies if this has been answer a 1,000 times. Wire sizing: I use "
https://www.solar-wind.co.uk/info/dc-cable-wire-sizing-tool-low-voltage-drop-calculator" to calculate wire size. Where I always get confused on is amps number.
Wire sizing is actually fairly complicated beyond the basics, so it is understandable to be confused. There are many variables to consider and some grey areas.
Personally, I would look at the manufacturer recommendation as a floor that I would not go below but may choose to exceed.
1. My inverter/charger is 24v 3000w 9000w surge so do I use 125a (3,000/24) which means a 4 awg wire (3% loss) or do I use 375a (9,000/24) which means 4/0 awe wire (3% loss)? Manufacture recommends a wire of 1 to 2/0. This wire would run from battery bank to inverter and from inverter back to battery bank
This will depend somewhat on your inverter. My guess based on the numbers you provided is that you have an Sigineer/Aims/Sungoldpower or Yiyen inverter. I believe these have a 20 second surge rating.
With a high frequency inverter you would use the continuous power rating (in this case 3000W), but with a low frequency inverter with high surge rating and duration, its a bit more of a grey area, since a surge could theoretically be many seconds or even minutes depending on the inverter.
One thing I notice off the bat is that you forgot to account for inverter inefficiency. This needs to be considered since an output of 3000W will require much more than 3000W on the DC input side. This is one of the most commonly overlooked factors. Generally I use 80% or 85% to ballpark inverter efficiency.
So the math would look something like 3000W / 0.80 / 24v = ~160A
2. My Voltage Converter Regulator DC 24V to DC 12V 40A 480W. Do I add 40a onto calculation of inverter...?
I would (for wiring/fuses that will carry both the inverter and DC current). Some consider the inverter a good enough ballpark estimate because many people don't have substantial DC loads or assume they won't be running when the inverter is maxed out. Both approaches are acceptable in certain contexts, and have pros/cons. I tend to err on the side of caution, and the first option is definitely the more prudent, and some would say more correct approach.
The way I approach total system current calculations:
1. Calculate max AC current:
[inverter max power / low voltage cutoff / inverter inefficiency] = AC Total
2. Calculate max DC current:
[DC distribution max / inefficiency (if applicable)] = DC Total
*(where DC distribution max can be DC-DC converter amp rating, fuse block rating, or total calculatred dc loads)
Combine AC total and DC total to get theoretical max system current.
