localboast
Looking for some guidance as I really don't know what's going on here.
Setup:
SCC: Epever Tracer 4215BN
Storage: 24v 200ah Lifepo4 with 100a BMS
Inverter: 2000w Pure Sine
Cables: All sized correctly (I know this will be asked)
My SCC and Inverter are connected directly to the battery terminals (with properly-sized fuses in between).
I have the SCC set to USER mode with Battleborn's Lifepo4 settings (and have confirmed with my battery maker that these are correct).
What's happening is that no matter what I set the Boost (absorption) to on the SCC, my inverter will quickly restart/brown-out (and beep twice which the manual says nothing about) when I hit the Boost value (I've tried 28.2 - 28.8).
The inverter has a High Voltage Protection of (30.0V+_0.3) so I should be safe there.
The inverter is never running above 200w.
The MT50 display will show OVD Error when the battery is full (which is fine).
I'm simply just trying to figure out why the inverter momentarily dies when my batteries are fully charged (and then over and over while there's still sunlight). Any ideas here would be AMAZING.
Thanks!
Setup:
Setting up the EPEVER Solar Charge Controller
The Epever MPPT solar charge controller has become a popular option for many customer applications. Find out how to set it up here!
battlebornbatteries.com
Thanks!
