See that is what you are missing. You are absolutely correct here (but your correctness is illustrating your misunderstanding of the term). As you said "nominal capacity cannot describe actual capacity" The point of the word nominal is literally to make sure its not confused with "actual" or "technical." Its not meant to be used interchangeably with actual capacity, its not meant to be used in place of actual capacity. Its meant precisely to note "I'm referring to the capacity in the name, not the capacity I actually observed"I'm using nominal as a placeholder in the context of this discussion. It cannot ever in my view describe actual capacity, which you summed up correctly as follows:
If you are looking for a technical specification (and you should be), nominal capacity is not what you want. You want one of two specs:
(1) minimum (rated) capacity (defined in the cell datasheet)
(2) actual or tested capacity (not defined anywhere because it varies cell to cell, and can only be derived through testing / use)
The minimum rated capacity (not the same as actual capacity) is in the datasheet. If you want to determine minimum rated capacity, just look at the datasheet.But then you add this:
Which is no help to finding out the actual, minimum rated capacity of a battery.
I really think you are getting hung up on a non-issue. Technical specifications are in the datasheet. That is where yo u go for tech spec's like minimum capacity. You will not find actual capacity or nominal capacity in the datasheet (because the former cannot be precisely known without testing or a test report and varies cell to cell and because the latter is not a technical specification, it just means 'named capacity' and is by convention the same as minimum capacity. It is not meant to take the place of more technical or more precise spec's
You say its not helpful to know that minimum capacity and nominal capacity tend to be the same in practice, but I disagree, while you should still verify in the datasheet, the knowledge that cell manufacturers base nominal on minimum means that a cell name is a pretty reliable indicator of the minimum rated capacity. So at a glance, you can get a pretty good indication of what a manufacturer defines as minimum capacity even if you don't have access to a datasheet.
Nominal capacity by definition does have a set value, its just somewhat arbitrary. I think what you mean is it cannot be derived from real world observation/testing, if so you are correct (which is part of what I've been trying to explain).Nominal capacity, by definition, cannot have a set value.
Correct (and does)Rated minimum capacity can and should.
