kencoultas
The trailer has a Progressive Dynamics PD5000 distribution panel (see above pic), and I’d like to use this panel with the solar components. Currently, on the DC + connections (shown on the picture above on the left, there are two large gauge wires going in. I believe one is from the battery, and one is from the PD9200 Converter. (see pic below)
As best I can tell, the white negative DC wires from the battery and the converter are feeding in here. (see picture below)
Can I wire my charge controller (in the places the arrows are pointing in the above pics^^) directly to my distribution panel in one of the following ways?
A) connecting the wire into the terminals shown above: for the positive, squeezing two wires into one terminal or port, since for the positive both terminals have wires in them, and for the negative, placing a wire into any empty port.
B) disconnect the converter, since I want to unplug completely anyway, and use the DC output wires from the converter to wire into my charge controller in the battery output connections.
C) would some wagos be good options to add a 3rd positive wire from the charge controller into the distribution panel?
Problem: The existing power distribution panel is using what seems like very large gauge wire , and my charge controller looks like this: the ports seem too small to get any good wire gauge into them, maybe 10 awg at best. Does anyone have experience with this brand or a type of charge controller that looks like this, and have any advice? I’ve seen the same exact one under a few different names.
(Pic of converter below–i won't be using this, so can I just take these two wired and connect them to my battery outs of the charge controller)
