Checkthisout
Solar Wizard
- Nov 14, 2021
- 4,810
There is a setting for changing allowing discharge at lower temps.
I had my truck camper in the back shed last winter and battery appeared dead in the cold. Brought it into the heated shop overnight and magically fixed itself. Checking the settings I saw low temp discharge was set at 15°C. It is set much lower now.
That's not the issue. The issue is that even with no charging current applied, the amps reading going into the bms goes to 73 even though there is actually 2 amps discharge occurring.
