Well, my 64-year-old ears could never hear anything, until the BMS went into alarm mode.There definitely is a high pitched sound, and I'm 99% sure it has to do with those same DC-DC converter chips. I'm currently trying to get the exact specifications of the chips in questions and waiting for someone to get back to me. If I can't get those, I'll just do the measurements on the circuit in isolation and figure out if there is a drop-in replacement I can find (should be).
I've held off ordering one of these to replace my Daly BMS.There definitely is a high pitched sound, and I'm 99% sure it has to do with those same DC-DC converter chips. I'm currently trying to get the exact specifications of the chips in questions and waiting for someone to get back to me. If I can't get those, I'll just do the measurements on the circuit in isolation and figure out if there is a drop-in replacement I can find (should be).
There are some android apps that allow generating sound at different frequencies.I have tried. Young people are much much more sensitive to high frequencies. They hear hf sound from large distance even when I don't hear feel anything .Well, my 64-year-old ears could never hear anything, until the BMS went into alarm mode.
Once you come up with a workable repair procedure are you willing to sell some of the required bits and bobs so that we do not need to buy a hundred?In any case, I've got 100 STI3470 chips coming. I'll order the RY3820 one as well once I hear back from the rep. I'll run some tests on the circuit in isolation, and swap some stuff around.
I assume you are referring to 5.5v Vin limit vs 18v Vin limit.I'm honestly starting to think they put the wrong component on there altogether. RY3820E and RY3820 (and others in that series) are easy to mix up: very similar designation, quite a difference in function. The fact that the problem is apparently solved by swapping with a replacement (i.e., different) component would explain that.
