TheCoachStone
In this video
Will says you can feed an LV6048 with only 120v if needed. I cannot find this in the manual. How does one do this?
Not sure what you are asking. Please specify the use case. Not familiar with the video referenced.In this videoWill says you can feed an LV6048 with only 120v if needed. I cannot find this in the manual. How does one do this?
He says something like “you can feed it with 240v or 120v.” I’m just not sure how since it has a 4 wire input.Not sure what you are asking. Please specify the use case. Not familiar with the video referenced.
Oh, it sounds like the unit can be configured for single 120V input or split phase. Is that possible with this inverter? The manual doesn’t support it. I think that unit is designed for split phase, they make a 6500 48 (6548) that is single 120V input and output. If you own one already, try plugging one phase into L1 and add a matched neutral and apply power. If it needs 240 to operate it will not power up or power down.He says something like “you can feed it with 240v or 120v.” I’m just not sure how since it has a 4 wire input.
Good tip, would have never thought. If there is a will, there’s a way…I have MPP 6048's
During a storm, Utility out for days, needed to charge up the batteries, but no solar, and my generator (at that time) was 120 V only output.
Connected the Generator following the manual - with a jumper between L1 and L2 inputs. Generator only, no Grid.
batteries charged.
It worked with this model.
Edit: shown on page 7 of the manual, phase angle L1-L2 is set to zero in Setting 28.
I only used this method once, during a storm, just to get through. I never needed to do again, as the need never came up again, and now I have a 120/240 8kW generator set up with a proper MTS switch. All that to say, I am not recommending the zero phase angle between L1 and L2, just pointing out that this model supports this - if you need it. Do not connect to utiltiy/120-240 with this setting. Read the manual carefully.
...and if it's in the manual, follow the instructions. LOL.If there is a will, there’s a way…
And if it's not, proceed at your own risk (with a camera running, just in case something spectacular happens)....and if it's in the manual, follow the instructions. LOL.
I mean, I guess this says that....and if it's in the manual, follow the instructions. LOL.
It sure does.I mean, I guess this says that.
Says the guy with a pretty spectacular icon pic...Sparky! LOL.And if it's not, proceed at your own risk (with a camera running, just in case something spectacular happens).
LMAOAnd if it's not, proceed at your own risk (with a camera running, just in case something spectacular happens).
I'm using it in this mode. Jump L1/L2 on both the input and output.He says something like “you can feed it with 240v or 120v.” I’m just not sure how since it has a 4 wire input.
