TheCoachStone
Hey guys,
I have a LV6048 with 4 100ah LiTime and a 16s 100aH system both at 48 volts. I took the LiTimes off, because I needed to test something else. Last night, I plugged in my EV and went to bed - the 16s was around 54% charged. I woke up and the truck was at 1%. I walked outside and the truck was not charging. I unplugged the ev charger, and, after a couple seconds, the LV6048 restarted. When I plugged the truck back in the LV6048 cut off again.
I'm guessing that I am pulling too many amps for the LV6048 now, but I am confused as to why. Why does another 48v 100 aH make a difference? If it needs more power, then why does it not just start using line power? Do I have a setting wrong?
Also, is there a minimum aH to support a certain number of amps of output?
