MarkSolar
Try to get 19 strand if you can, it's easier to crimp on MC connectors if you're doing it yourself. There are a range of strands available, from 7 up to higher numbers. 7 strand is too stiff and hard to get a good crimp.
I don't know anything about Staubli.. I tend to stick with either an Amphenol or Tyco connectors so I don't have to worry about cheaply made garbage.Any thoughts on the following MC4 Connector?
PowerStore | Wholesale Solar Inverters, Grid-Tied Solar
PowerStore provides a one-stop shop for wholesale solar products, including grid-tied solar, off-grid solar, and solar storage solutions. Same-day shipping. Shop now!thepowerstore.com
I would need 6 sets of them to connect to the panels (two for each series, 6 series total). What I am not sure of is if they will play well with the MC4 connectors on the Hyundai panels I'm getting. Any takes?
Any takes on the crimper they have? https://thepowerstore.com/mc4-crimp-tool.html
Thanks! I might get some of the smaller parts from Renvu then.
Did you guys have to put your wire that ran along the ground mount framework in conduit? If so, how did you "exit" the conduit to go to the panels? Was it something like this?
MidNite Solar 1/2" 600V Heyco Strain Relief accepts two 5mm PV wires (SKU Part Number MNSR-1000)
1/2" 600V Heyco Strain Relief accepts two 5mm PV wiresthepowerstore.com
What did you do for wire management on the backside where the extra PV cable wasn't in conduit? Some sort of clips, zip ties, etc....?
That's exactly what I used, only I think mine are either Ideal or Kline or something.Any comments on the crimpers or do ya'll think I should look for something better?
MC4 Crimp Tool
Information Ratcheting crimp tool compatible with DM-MC4 connectors. Wire Cable AWG 14-10).thepowerstore.com
Should I run into compatibility issues between the Staubli MC4 connectors and those on the panels. Looking at the datasheet, it says: MC4 compatible.
