Maxxim
- Jan 2, 2021
- 31
Hello all. I'm new here on the forum, and also a newbie with lithium batteries. And sorry for my english, it's not my native lauguage.
I have a small fishing/trolling boat that runns with an 60hp outboard motor(17amp alternator) and also has a bow mounted electric gps motor. Have two lead acid batteries, one 80Ah for start and boat electronics, and a 110Ah for the electric motor.
The boat has some electronics, lights, separate Garmin sonar and chart plotter, and a Furuno radar etc.
I always try to keep the trolling motor battery(110Ah) topped up after a fishing trip with 90W solar panel(mppt contr), or with a separate battery charger. But the 80Ah start battery seems to be a little bit low on charge if the outboard alternator hasn't have much time to charge. Some fishing trips with much electric motor use and only short bursts with the outboard.
For next summer I wan't to update the system a little bit. Wan't to replace the trolling battery with lithium. Ordered cheap 100Ah LiFePO4 packs from china Aliexpress and a Overkill 120A BMS from US. But I want to keep the lead acid battery as start battery. I would like that it's possible to charge both batteries with the outboard alternator, solar panel and easily with a separate battery charger. But how is the best way to connect everything?
Would like to use existing parts and components I already have. But if they can't be used then I'm willing to make some investements. Advice on what to use and best way to connect everything is much appreciated.
- 110Ah lead acid battery
- 100Ah LiFePo4 battery
- 90W solar panel
- 10A MPPT controller
- Victron Orion-Tr 12/12-9A DC-DC converter
- Charging relay (max 125A)
My idea is to use the 110Ah lead acid battery as main/start battery that would be charged by the alternator, solar panel and an outside battery charger. And then use the Victron DC-DC converter to charge the LiFePO4 battery from the main battery. Any idea in this? I have no idea how the Victron would handle the sudden peaks that happen when the BMS shut off the charge.
Hope you get an idea of the setup, as my explanation may be little bit unclear.
- 90W solar panel
