SolarScott
- Sep 27, 2022
- 476
EG4 6000 running three inverters, have always had horrible flicker with incandescent lights. Did up date last Monday and again Friday. Host inverter is still different from slave inverters and flicker did not go away. Today, I am making 3KW per inverter and at 60% use on each leg. Stove, dryer, dishwasher, small electric heater and all t.v.'s computer etc. running. Same as always but now, no flicker. NONE! What gives? ALso my display says battery level over 55. Normally it never indicates about 54 volts. Right after the first update it went all the way to 56.2, the setting I have set up under USE, but then after a while it was back to never about 54. Today no flicker and headed towards 56.2 again. ?????
