fat_old_sun
- Nov 16, 2019
- 199
you mean parallel?The only issue that I have with EPEVER or EPSOLAR is that you can not put them in series
Correct me if I'm wrong, but I thought You could run two independent systems (solar panels and controller) to charge the same battery (providing the charge settings are the same).
I don't understand. Putting the output of two scc's and putting them in series? Why? Or is the input voltage to low to allow panels to be in series?You can .. but both of them will act independent .. if they are in series then one is the Master and one slave ...
Oh, Thanks. Your a wealth of information.You can .. but both of them will act independent .. if they are in series then one is the Master and one slave ...
Yeah, series would double your voltage.. never a good idea..I MEANT TO SAY PARALLEL ... SORRY ....
It depends on what you are talking about, of which I am still wondering. PV input? Charger output? What?Yeah, series would double your voltage.. never a good idea..
I'm also running two SCCs in parallel and their setting are not the same on purpose. I want the second SCC to back off when the batteries are near full and let the larger SCC manage the final spike over 14v. My point is they don't have to be same, they both will act independently as a power source.I have done this for the past 2 years without any problem.
I’ve got balancing problems with it and can’t keep them in balance. Running .8a load and after 8 hours I’m .3v out of balance. Driving me nuts!i Don’t! Not yet atleast. I’m still working on it.
I finally bought a bench top charger so I can put a steady current/voltage to them but I was using a lipo charger that did life. The problem is it will only charge at preset voltages. The highest being 3.3v which it stops at 3.2. I’m guessing since it stops at 3.2/3 that it’s the top of the discharge knee so I’m missing out on 60-70% of my potential capacity when using this charger. I have solar but I’m not confident on the charging values I’ve set(which is why I came here) people keep pointing me to a sticky will left but it only defines like 3 values, boost,float, and something else. The epever has like 20 values I need to set and I can’t seem to get assistance with it. These cells where expensive so trial and error are not an option for me.The higher the voltage is, the more out of balance they will become as well as nuts you will be driven.. if you wait for the BMS, charge them as a pack with the BMS balance, you will discover all will be well.
My attempt to balance cells also drove me loony. It's nice to have the orderly path but with patients, all cells, especially new will eventually balance with cycles.. if you try to force them, you can actually reduce their calendar life while you wait for the BMS.
What do you mean “wait” for the bms? I’m using the bms when I discharge and it’s still getting way out of whack and that’s with a tiny load .8a. 1 3p pack is barely dropping in V and the rest are all over. I’m hoping with a bench top charger and a CC I can actually charge them and top balance. If you find a lifepo4 cell stuck in your windshield in the morning it was probably me.....The higher the voltage is, the more out of balance they will become as well as nuts you will be driven.. if you wait for the BMS, charge them as a pack with the BMS balance, you will discover all will be well.
Here are my settings for EPever SCC. My battery capacity is 1200Ah, it will only accept 999. If you use these settings, I think they just might balance eventually. Charging to 3.2v per cell can not balance because 3.2v covers a wide range of SOC, something like 70% to 40%.. To begin to charge and it mean something, the cells need to be upwards of 3.4v or higher. 3.3v is just the beginning of the knee. You can go as high as 3.65v per cell to balance if they are that far out of wack. You can charge each cell bank to 3.5v but with 3p, it might take a while.. It might be better to charge the pack to 13.6 volts and wait for one of the cells to hit 3.5v before starting your manual top balance.
Sorry for asking but is there any reason you did not set the equalization voltage to 0 ?
