Hello all, I am building 4 of the following batteries:
o 280ah Eve cells x 4 in series for 12vdc nominal
o JK BMS 200ah with 2ah active balancer
o 2/0 wiring from battery negative to BMS and from BMS to negative post on battery box
o 2/0 wiring from battery positive post to positive post on battery box
o BMS start switch from BMS to front of battery box
Batteries will all run separately to a Lynx power in or distributor via 2/0 wiring (ensuring same length wire
I am pondering using a 250ah T-class fuse in each battery, as I have room in the case, is my thinking flawed?
TIA, Jeff
TIA, Jeff
