D90Don
I am building a 48v System and I have a question regarding fusing the Victron Lynx Distributor 1000. The following will be connected to the Lynx Distributor: SOK Battery Rack (5 Batteries 48v/100a connected in Parallel), Victron Multiplus II 120/35, and Victron Smart Solar MPPT 450/100. Should I fuse the Lynx Distributor with a 125a fuse for the Battery Rack, 35a fuse for the Multiplus II, and 100a fuse for the MPPT Controller with 58v rated MEGA Fuses? or go with slightly higher current rating MEGA Fuses? Also, there is a 4th opening / slot that I currently don't plan on using, but I've seen some on the forum recommend fusing so there is no red light on the Lynx Distributor. Any recommendations, most appreciated. Thanks.
