I built a starter/learner system somewhat similar to yours, with six 210 W panels for a total of 1.26 KW, and a 24 volt / 3000 KVA (basically 3000 W for discussion purposes) Victron inverter. I started with one Amperetime 100 AH battery, then added another about four weeks later. After another six months or so I added a third. I'm very happy with them for a stater/learner system and have no regrets. To power the "shed" buildings for which I built the system, I doubt I'll need to change anything for the next decade.
Some here say 24V will be useless but that's a gross exaggeration and overstatement that I wouldn't worry about if you've already purchased the equipment. That said, I would go 48V if I were starting over, simply because it will more easily scale and the prices now aren't that much more than 24V. There's absolutely no way I'd go with a 12V system or buy 12V batteries and connect them in series. But if you've already purchased some stuff, you should be fine. Take a look at
@Will Prowse battery tear-down videos and go with a brand he likes, and you'll likely be as happy as I've been. BTW, I do advise adding in a good shunt (Victron is awesome) as it's the only accurate way to measure state of charge with lithium batteries.
