hagensieker
- Jan 30, 2020
- 136
I have 400 watts of panels pointed 5 degrees south of south I hit max output about 2 PM. On a cloudless day I'm tossing in just over 400 watts into 2 Battleborn 100ah and soon to be 3 as soon as the FedEx guy shows up with it in a couple days.
I top off almost every day before noon when I'm generally at half PV input capacity. That's all good as far as I'm concerned. However I don't do much with the power until the evening. I notice that when the system does pull from the battery such as when my 12v fan is on or the Alpicool C20 fridge compressor kicks on that the Solar charger feeds me whatever I'm consuming. If the fridge is pulling 35w the solar charger gives me 37 or so watts.
This is kind of making me feel like "I'm doing it wrong". I should be charging every device in the house, or running the vacuum off of the solar.........you get the idea. I have a 2000 watt inverter. I think I'll start using my Jackery power stations a heck of a lot more in the other rooms and charging them during the day off the solar board.
I even wonder if I can get one of those new, super efficient split unit AC's and run off of it during the day for the upcoming summer months. Or a small efficient window unit. Time to break out the calculator. Some of those new AC's sip power.
At any rate I think I'm letting a lot of sun power go to waste even though my current needs are being met. I never really take advantage of those peak sunlight hours.
