RoadTurtle
- Mar 30, 2022
- 366
Mixed use of Zamp and other brand panels (470w). RV came with Zamp panels and Zamp 30a controller. I've since added two 100ah battleborn batteries, and upgraded the Progressive LI charger. Neither the solar charger, nor the 120V charger go into bulk mode. Progressive is blaming the solar controller for raising system voltage preventing it from going into bulk mode. Zamp is blaming the batteries for not taking higher voltage. Battleborn, states they are the recipient of whatever is being delivered.
Plans are to climb up on the roof and check the battery voltage of each panel near noon tomorrow (Lake Havasu AZ). Also to check the 120V charger voltage disconnected from 12V.
It takes forever to charge the batteries to full charge, and I'm not sure they actually ever get there. While the 2 100ah batteries is less than I'd like to have, I'm apparently using more electrons than I expected, or I'm just not getting to a full charge.
Last night for example, it was cold out, so furnace was running a bit. My 2200w generator was started at roughly 5 pm, it will run for 7 hours, while the charger and parasitic loads was pulling 680watts. I had other loads running later, including 150w TV for a couple of hours. Gen ran out of fuel during the night, and at 7am, battery voltage was 12.0v. I don't mind running the generator, as I realize 200ah is a bit light for my expectations, but this seems to be not getting me to where I want to be. I had better performance out of GC2 lead acid batteries, but I also knew the charger was doing a good job too.
Any thoughts on what I'm missing here?
