Greetings from Tug Hill NY
nycamper62
Syracuse, NY
Hey, I am into practical & conservative off grid solar system maintenance & use. Looking forward to learning & sharing advice on solar before I expand & improve my system at camp. It's my peace of mind there. I started out over a decade ago with a few small hf kits, was an active member of an old diy solar form back then. My system today is about a half kw, with a 30amp pwm controller feeding a 4x 6v 12v lead acid bank in series/parallel. This keeps my rv/camper ventilated, including the composting toilet. Lights, entertainment (am/fm/cd/usb/bt deck) and a laptop primarily used as a dvd player. Also use a 1000w pure sine on occasion to charge my tools, and back up for the fridge.
In summary:
3x 100watt polycrystalline
1x 145watt polycrystalline
1x 60watt polycrystalline
9x 45watt amorphous
pr30/30 (steca knock off)
4x 6v gc2's (15's still going)
Purchased my 1st polycrystalline back when monocrystalline panels were still - more coin $. And when the whole 1$ a watt thing was just an nice thought. Before anyone sneezes at the amorphous panels let me say they afforded a learning curve, they trickle charged in overcast & they still work. But they are aging and I'd like to phase them out. Plus repurpose the 60.
There is a few things to consider before I expand & go to mppt with about 1kw in mind. There's the aging battery bank. Should I include the remaining panels, which means a second controller, more wiring, buss bars, etc. And of course a new chainsaw blade to help open up the canopy.
Happy camping.
I am VERY curious how you have these connected to a 30A PWM controller at 24V.
I mean... they gotta be in parallel...
And they gotta be 24V panels...
Very sketchy numbers though...
About 8 amps lost in translation if panels ever produced full output...
In parallel, 12v panels.
Not visible but panels are wired into a combiner box into copper buss bars, then wired through conduit into the rv/camper.
Wait...
12V panels all in parallel connected to a 24v bank?
How does the system charge?
Boost converter?
I'm not dissing them at all!
I am thinking that with your 30A PWM controller, if you switched to an MPPT SCC, you can probably arrange your panels into a higher voltage array to charge better under low light conditions (early morning, late afternoon, overcast days).
Heck, i'd consider keeping the PWM for any panels that don't mix and match an MPPT should you upgrade. It would also provide some redundancy.
Maybe your hodge lodge of panels can be kept in service. I'd definitely get an MPPT SCC though (the heart and brains of every solar system).
I'm not missing them at all!
Yeah, I'd pull the 9 panels into series on a 60A mppt, leave the rest on the pwm, and probably gain a lot of usefulness of the system.
How many volts are your "12V panels"?
How many amps do you figure you have adding the amperage (Isc to Imp) of all panels? 35 to 40A?
The two rich solar 100w panels are now in series to the combiner box.
The dmsolar 145w
The cynery 100w
These two are in parallel to the combiner box. Then the box feeds a 25foot run to the controller inside the camper.
Edit: the dmsolar & cynergy panels are the oldest but in good shape. As camp is in a woods setting I thought of putting them in series as well to help with shading. But I am not sure of the loss and they are not equal wattage.
By the way over this last weekend I brought a digital tv & antenna up to camp to test what if any channels I could get. Turns out with the right antenna placement about a dozen channels come in. Including the one that broadcasts the super bowl.?
With the inverter just powering a small tv, the booster, phone, some led lights & a small crock pot I discovered my first attention to expansion needs to be the battery bank. Went from 12.8 to about 12.2 in less than an hour.
Ahh ok, the two rich 100w panels are in series, the cynergy is not.
This seemed rather odd. What was your thinking on this?
Ideally, each string going to the combiner box should have as equal voltage as possible because all strings connected in parallel by the combiner box will clip the voltage of all strings to the lowest strings' voltage. Thats lost watts, never to be recovered.
Well, placing two 100w panels in series seemed like a way to deal with some shading issues from trees depending on the time of day. Then I thought of placing the other two in series as well but they are different specs. Now I'm wondering if I should put them all back to parallel.
Before I expand and go with matching panels I'm working with what I bought 10 years ago plus the two new rich 100w set.
